Truck wont go over 2000 rpm's while in drive
Old Dec 8, 2015 | 06:01 PM
HippyKiller77's Avatar
HippyKiller77 is on a distinguished road
Default Truck wont go over 2000 rpm's while in drive
I have a 87 K5 Blazer i've been working for the last 6 months and have now found a new problem . while in drive the truck will not go over 2000 rpm's but when in park or neutral it rev up past 2000. Any help will be much appreciated
Old Dec 8, 2015 | 08:17 PM
odat's Avatar
Sorry can't help ya I happen to be a old Hippy
Old Dec 8, 2015 | 08:40 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Old Dec 11, 2015 | 08:27 PM
ShadowZone's Avatar
ShadowZone is on a distinguished road
Default Check Out Your Cat!!!!!
Do you feed her properly, hug her in the wee hours of night.
A Catalytic Converter will clog and cause theses problems under load or when you do not tell them you Love them everyday. Take off your EGR Valve and cruise around the block a couple of times. You will probably see a Miraculous Transformation, Just be Sure to say GETTY UP nicely.
IF THIS DOES NOT ALLEVIATE YOUR SYMPTOMS! Post back, your SHE could be a HE in which case I am way off base here, and only antagonize the problems you are suffering from.
er0ck273
Jul 31, 2015 04:10 PM
95ls2door
21
Jun 17, 2010 03:02 PM
carterx
May 21, 2009 08:30 PM
baldmikey96
Jan 2, 2008 09:10 PM
xxx6thirty6
Sep 7, 2007 06:18 PM
