U joint part number
Old Feb 4, 2023 | 07:20 PM
gojimmygo111's Avatar
gojimmygo111 is on a distinguished road
Default U joint part number
HelloI have a vibration at the pedal when accelerating over 80 km per hour. It feels like excessive play at the u- joint and a clunking sound when shifting into drive from park or reverse from park or drive. What manufacturer replacement part should I stay away from and how high should I go in price? There seems to be many joints that will work and they increase in price as I go down the list. I assume other than having a grease fitting, some may built stronger than the lower price ones?
Old Feb 5, 2023 | 07:51 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
I am no expert on these but I recognize Spicer as a good name in these things. If that's an option, it's the one I would take. You'll probably find guys on both sides of the argument on having zerks on them. They frequently come from the factory without and last a long time.
Old Feb 5, 2023 | 12:44 PM
What he said. There are several brands of "good" u-joints, but I always buy Spicer if I can. You can't go wrong with them.
Sometimes it's nice to have grease fittings, but I've also had very good luck with the Spicer Life series joints, which are not greasable.
Old Feb 12, 2023 | 05:44 AM
Thanks for the tips. The vibration was getting worse and worse. The UV at the rear diff was hurting. Everything running well now.
Davecubs14
Jun 4, 2016 10:09 AM
red1127
Jun 28, 2015 03:41 PM
RedOne
Mar 5, 2012 07:51 AM
reeladdiction
Oct 24, 2011 06:35 PM
sktdarkstar8
Aug 11, 2006 04:30 PM
