Upper Intake Manifold
Old May 29, 2011 | 08:38 PM
EddyKJ's Avatar
EddyKJ is on a distinguished road
Question Upper Intake Manifold
Hi,
I'm a new member, hoping someone might be able to shed a little light on my situation. Can't seem to get the upper intake manifold off. Read an old thread suggesting penitrating oil and a little heat (no flame), someone even mentioned hitting it with a hammer. Tried all that, though was pretty delicate when hitting it with a hammer. Any other ideas? My ride is a 1995 Chevy Blazer.
Old May 29, 2011 | 08:53 PM
warthogdriver's Avatar
i will be doing this job myself shortly...
this is what i found..hope it helps
How To Replace Intake Manifold Gaskets On A GMC Jimmy 4.3 Liter V6 To Fix A Coolant Leak - GM Truck Engine Repairs
Old May 29, 2011 | 11:29 PM
EddyKJ's Avatar
Thanks, unfortunatly it doesn't have any tips on my problem. I even trid using a crow bar and found a good spot to try and hit it loose, with no luck. Doesn't make sense, I'm just worried about breaking something if I put anymore force into it. Hope you have more luck with yours.
Old May 30, 2011 | 07:25 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Are you sure you got all the bolts out? Don't forget the one towards the front in the middle, under where the Vortec cover was (near the pcv hose connection).
Old Jun 1, 2011 | 07:55 PM
reddheadnla's Avatar
reddheadnla is on a distinguished road
I had the same problem with mine and it turned out to be 2 bolts that i missed. Make sure that you have got ten out all together for it and good luck with it. Hope that helps you.
josemateos
Jan 15, 2014 03:33 PM
ABN31B
Engine & Internal
15
Jan 8, 2011 03:43 PM
benshuey
Feb 21, 2010 09:18 PM
hhu1666
May 31, 2008 10:19 AM
Jerseyboy
Apr 27, 2006 03:28 PM
