Vibrations when accelerating
Old May 8, 2010 | 07:55 PM
BlazerGuy2001's Avatar
Default Vibrations when accelerating
Hey BlazerForum,
so ever since i got my blazer whenever i accelerate at a somewhat quick rate i get a fairly harsh vibration. I am not sure if this is a common problem with all the blazers or if it is due to the 3" lift that i have. Could someone please offer some advice as to what might be wrong?
BTW its a 2001 ZR2 Blazer
Thanks
-Derek
UPDATE: just read a post of someone that had the same problem. He replaced his rear u-joints and he said the problem went away. Could this be the same problem that i am having?
Old May 8, 2010 | 11:01 PM
R134A's Avatar
R134A is on a distinguished road
I don't know who put the lift on the truck but lifting the truck could cause the drive shaft to go out of balance. Look at drive shaft to see if maybe a weight did not come off on its own, you will see a witness mark where it use to be. It definitely could be a U-joint also.
Old May 8, 2010 | 11:02 PM
i put the lift on but it was only 3" shackles and a 1.5" tbar crank and i sure didn't knock one off but i will check tomorrow thanks for the input
Old May 9, 2010 | 11:59 PM
ohsofly's Avatar
I would suspect your ujoints... they dont cost too much, and are not too hard to change. You can undo your driveshaft at the diff and try moving them, they should move very easily each way, if they feel tight then change them.
Make sure your replacements are the type with a grease zerk on them so you can lube em up at oil changes...
andomwoodard1977
Sep 5, 2007 09:25 PM
bleepstreet
Jun 5, 2007 11:35 PM
blazerbob
Mar 28, 2007 09:19 PM
Acer2428
Mar 29, 2006 02:57 PM
sonicdrft
Mar 16, 2006 03:11 PM
