VSS Help
Old May 20, 2012 | 03:18 PM
chrisgascoigne's Avatar
chrisgascoigne is on a distinguished road
Default VSS Help
Curious as to if anyone knows exactly where the Vehicle Speed Sensor(VSS) is located on a 2000 2wd Blazer. Just bought a new one and need to replace it.
Have been having some issues with Improper shifting and it staying in 2nd gear with no shifting/downshifting
Any help would be awesome, thanks in advance!
Old May 20, 2012 | 06:40 PM
Your 2000 2WD has 3 sensors: One for each front wheel and one in the transmission extension housing. The PCM uses data from the one in the extension housing for determining several things, transmission shift points being one of them. If there's a problem with any of the sensors, or the wiring for them, a DTC, (Diagnostic Trouble Code) will be set and the SES, (Service Engine Soon) and/or ABS light will come on. No DTC's or SES light = sensors and wiring are working properly. If the transmission is hanging in 2nd gear, the problem might be a sticky shift solenoid in the transmission.
Old May 20, 2012 | 07:27 PM
The lights come on and off randomly or at least it seems random to me as I don't know the exact issue. I could take it in for diagnostics but would that be worth it if the lights aren't on at the time. As there would be no codes to pull.
Old May 20, 2012 | 07:36 PM
The lights come on and off randomly. Or at least it seems random to me as I do not know the exact reason it is doing this.
Old May 20, 2012 | 07:58 PM
DTC's will remain in memory, even if the light goes off, for a certain number of drive cycles without a failure. The typical code scanner that the auto parts stores use to retrieve DTC's will not retrieve ABS DTC's, strictly powertrain codes, (engine & transmission). A more "sophistocated" scan tool must be used to retrieve ABS DTC's.
RexCastle
Nov 17, 2012 08:59 PM
ryanb25
May 25, 2011 11:10 AM
fbuchanan
May 24, 2011 01:57 PM
Doug W
Mar 8, 2011 07:24 PM
wolv2401
Jan 6, 2007 04:26 AM
