Wants to start on first try and if it doesn't, it won't start until the 4th try.
Old Jan 26, 2018 | 12:51 PM
brushfire02's Avatar
brushfire02 is on a distinguished road
Default Wants to start on first try and if it doesn't, it won't start until the 4th try.
2000 4x4 zr2 wants to start on first try, and usually does, but if you can't get it to start first try, good luck. It won't start until the 4th or 5th try after that. Sketchy because my battery dies often.
Old Jan 27, 2018 | 10:41 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
Do a fuel pressure test. I think Autozone and others loan the testers.
With the truck off, but key on, it's supposed to be around 60psi. It should maintain above 50psi for 10 min after the key is off
Old Oct 20, 2018 | 05:38 PM
ajfetterman's Avatar
ajfetterman is on a distinguished road
**Edit**Not sure how rhis post ended up here and not on mine. Sorry guys. Lol
So if grey is pump power, I will have to double check that terminal again. I don’t recall seeing voltage. I assume it will be constant voltage when the key is on?
Had and to wrap up earlier today for a birthday party. Next time I get out there that is where I will start.
The 5v was on the purple which looks like it is not involved for this issue.
Old Oct 20, 2018 | 11:06 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
I agree with oldeerslayer, it sounds like a fuel issue, most likely the fuel pump. Best check that fuel pressure.
Prolsc
Sep 6, 2019 04:52 PM
Rhodes19
48
Feb 15, 2013 09:46 PM
FreeTime
Sep 8, 2012 01:38 AM
1955chevyhams
Sep 11, 2008 04:53 PM
mjj
Nov 19, 2006 11:34 PM
