WARMING UP?
Old Oct 3, 2008 | 09:02 PM
gohan69's Avatar
gohan69 is an unknown quantity at this point
Default WARMING UP?
HEY GUYS I JUST GOT A 96 BLAZER TO GO ALONG WITH MY 01 AND WHEN I GO IT HOME I OPENEND UP THE RADIATOR CAP AND SAW ALL KINDS OF GUNK IN THE RADIATOR BTW IT HAS 150,000 MILES ON IT SO I TOOK IT AND GOT IT FLUSHED TWICE WITH NEW CAP AND THERMOSTAT IT STILL WONT HEAT ALL THE WAY UP IT GETS CLOSE TO ID SAY 180OR 185 BUT STILL WONT REALLY OPEN ALL THEY WAY UP AND I ONLY REALLY GET HEAT ON THE TO HIGHEST SETTINGS WHAT WOULD BE CAUSING THIS MAYBE A BLOCKED HEATER CORE?
THANKS
Old Oct 3, 2008 | 09:55 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: WARMING UP?
How was it flushed with a hose connected to a tee, or with a power flush, or by disconnecting lines. Its possible the gauge is wrong due to faulty gauge or gunked up sensor. The lack of heat could very well be due to a blocked heater core depending on the flushing procedure you used it should have cleared it up unless it is really blocked with rust and sediment.
Old Oct 3, 2008 | 09:59 PM
gohan69's Avatar
THE FLUSHES WERE DONE BY A MECHANIC WITH THE MACHINE AND HOSES POWER FLUSHED
Old Oct 3, 2008 | 10:34 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
What thermostat was put into it? There are 185º t-stats available; it's possible one was put in by mistake.
Second, using all caps is considered shouting - and is much harder to read.
Old Oct 3, 2008 | 10:54 PM
gohan69's Avatar
sorry no i made sure it was a 195 degree so i know it cant be that
Old Oct 4, 2008 | 01:03 AM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
check the sensor in the drive side head.. between the exhaust manafolds. mine was reading low and some times real low so i changed it. i belive thats the one for the gauge. fixed it for me acdelco part for 11$ try it...
Old Oct 4, 2008 | 12:34 PM
rriddle3's Avatar
And be sure you're using a Stant brand radiator cap.
blazer485
Nov 24, 2013 09:42 AM
Xenon
Mar 6, 2012 06:03 PM
Milli
Apr 29, 2010 10:35 AM
