Water pump question?
Old Feb 8, 2008 | 08:00 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default Water pump question?
Has anyone here had any problems when they replaced their water pump to find that the gaskets between the block and pump keep blowing out!!!! This is now twice this has happened to me in the past couple of months, I replace the water pump today from a real auto part store instead of autozone which is where the other pump was from... The gasket was actually getting cut along the edges of the pump, and it wasnt overtightened either.. Thanks Boyz...
Old Feb 8, 2008 | 08:22 PM
thegr81's Avatar
Default RE: Water pump question?
Are you using rtv with it at all??? Also are you making sure all prior material is cleaned away prior to putting on a new pump??
Old Feb 8, 2008 | 10:47 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
yes!!! replace the fan clutch I know it sounds wired but that is it. The fan clutch is out of balance, and sort of jiggle the gaskets loose. Thats what my proplem was, exeptI had to replace the radiator because the fan come off the water pump, and put a hole in it. But hey every thing worked out hope this help.
Old Feb 9, 2008 | 12:02 AM
Hanr3's Avatar
What I find that works for me.
Scrap all the old gasket material off.
Use a shop vac to suck some of the water in the block holes out. If you dont, no amount of gasket sealer will stop the leaking.
Clean both mating surfaces with brake parts cleaner. You want both mating surfaces bare metal clean with no gouges, burrrs, etc.
Use teflon tape ont eh water pump bolts, couple of them go into the water jacket and the water will seep out through the threads.
Place a thin layer (spread it around with your finger so that it is about 1/16" thick) of RTV on the pump and place the gasket on top. Spread another layer of RTV on the gasket, carefull not to tear it, or move it out of place.
Slide a bolt through one hole and slide the pump into place. Doesn't hur tto practice sliding the pump into place without the gasket on it first so you learn how not to hit the gasket on the way in.
Tighten to goodentight specs. Let it sit over night or as long as recommended on teh RTV.
Once the RTV cures, then add coolant.
Take your time, its frustrating as hell when it leaks. Sure its a simple job, however there are some pitfalls that suck if you try to take short cuts.
Old Feb 9, 2008 | 06:06 AM
2002XTREME's Avatar
Thank you all for the ideas on this annoying problem....
Old Feb 9, 2008 | 08:44 AM
FreeBird's Avatar
FreeBird is an unknown quantity at this point
as for the ATV gasket maker, I would use the gray. Works wonderul for pumkin covers and other areas where they are known to blow out or give way. Makes it kind of hard to remove the next time (I have to use my biggest rubber hammer to help preswade it loose), but worth it in the long run.
BouncingRadical
14
Nov 27, 2015 12:30 AM
rxjimmy
Apr 14, 2015 09:49 AM
wierdo124
Jul 21, 2013 09:52 PM
shesrdy2laff
Oct 14, 2009 12:46 AM
myetman
Jul 4, 2005 11:56 AM
