weird noise
Old Jan 5, 2011 | 09:54 PM
Glasshouse's Avatar
Glasshouse is on a distinguished road
Default weird noise
I have a 4.3L 02 blazer and i can hear a real fast rattle noise inside my cab, and when i got out to investigate i found that it appears to be coming from the hose/line that is coming up out of my driverside valve cover. The rattle comes and goes if you rev the motor it stops for a second or so and then starts again. Any clues what this part is or why it would be doing that? Thanks!! PS. tried search and didn't find much . . . . . .
Old Feb 2, 2011 | 06:06 PM
Rottidog's Avatar
Not sure as my 4.3 is different with the additions I have on it now but isn't that the PCV valve? Take a pic or 2 & post em. One of the engine bay & one closer up of the part. If it is the PCV they should be under $20. I know they rattle when you take them out & shake em.
Old Feb 3, 2011 | 11:03 AM
blazinloud's Avatar
there is a plunger in there that moves up and down, it may be touching your throttle cable. can you feel the vibration on the gas pedal?
just zip tie it or something out of the way....
gERgMan
Sep 6, 2008 07:27 PM
2dr5spdblazer
Oct 4, 2006 04:25 PM
blazinloud
Engine & Internal
Sep 10, 2006 07:01 PM
XBlazer01
Jul 19, 2006 02:53 PM
pepsi21463
Engine & Internal
Aug 13, 2005 12:35 AM
