Weird sound?
Old Jan 31, 2009 | 09:05 PM
dfreemansmith's Avatar
dfreemansmith is an unknown quantity at this point
Default Weird sound?
I am hearing anoise like something is shaking or loose and you can only hear it really when the truck is idle and when I start my full size blazer. When I look at the belt I can see the bottom pulley shaking like it is lose. Is that normal? Since it is shaking could that cause the knocking? Does anybody know the name of that pulley?
Old Jan 31, 2009 | 11:17 PM
DdayK5's Avatar
DdayK5 is an unknown quantity at this point
Default RE: Weird sound?
The bottom pulley is attached to the harmonic balancer and that is bolted to the crankshaft. It could be possible that the balancer has become out of balance and cause the shaking. It's hard for me to explain how to check to see if the balancer needs to be replaced. There is a strip of rubber within the balancer, you could see if the rubber material has deteriorated or the outer ring has shifted.
Old Feb 1, 2009 | 10:13 AM
Should you just be able to look down at the crankshaft pulley and see it shaking while all the other pulley's dont shake at all? Does anyone know about how much a crankshaft and a harmonic balancer cost?
gERgMan
Sep 6, 2008 07:27 PM
blazerboy124
Oct 15, 2007 06:54 PM
davtak
14
May 14, 2007 10:02 AM
schnitzer00
Apr 17, 2007 04:54 AM
schnitzer00
Apr 12, 2007 07:53 PM
