What oil/engine tick?
Old Sep 8, 2008 | 01:18 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default What oil/engine tick?
What Oil would you gueys recommend me using in my 2004 Blazer im doing an oil change in an attempt to get rid of the annoying ticking noise the engine has. It makes no difference if its warm or cold and it varies with the rpm level. the speed of the tick that is.
Im running 10w-30 right now but i believe i will switch back to 5w-30.
Thanks gueys.
Jared.
Old Sep 8, 2008 | 01:20 PM
Default RE: What oil/engine tick?
Sorry to say, but if you have a tick, usually it will not be cured by changing the oil type.
With that said, you probably should be running 5w30 anyway.
Old Sep 8, 2008 | 01:31 PM
jman_08's Avatar
Yeah i figure changing the oil is worth a shot i was told it was the injectors but i have a very hard time believe that any ideas its very annoying tick in the engine which gets faster as u accelerate especially heard at idle. But still very audible when under load?
Old Sep 8, 2008 | 01:53 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
if the ticking is that bad sounds like its time for a rebuild or replacement motor..
Old Sep 8, 2008 | 03:27 PM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
If it is a hydraulic lifter sticking, I suggest use a quart of Schaler Risolone with every oil change and add one quart ofRisolone between 4,000 mile oil and filter changes in addition toany regular oil the engine might use. I have used Risolone many times in other engines with excellent results and I use it routinelyjust a preventative measure.Risolonewill usually solve the problem of sticking lifters unless it is a pressed-in rocker stud that has pulled out a bit.By restoring lifter function you will also restore valve action with will noticeably improve engine performance, especailly if it is an exhaust valve lifter that is malfunctioning. The exhaust valve closing point is the most important of all the valve events.
False claim laws suits filed against companies that make oil additives such as Slick 50, Prolong, Restore, among others, have been successful but there has not been any false claim law suits against Schaler Risolone.ZMax won a false claim law suit recently but that does not mean I would use the stuff.
Old Sep 8, 2008 | 10:16 PM
jman_08's Avatar
As u said above changing the oil did nothing but i isolated the noise it is coming from the right side of the engine right at the engine block is the loudest would that be a lifter?
Old Sep 8, 2008 | 10:47 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
could be.. id take it to a shop asap... setting the backlash can be a pain so hopefully it just be came loose some how..? not likely but hopefully
Old Sep 9, 2008 | 07:03 AM
Not to scare you, but it is possible that a cam lobe has worn down causing the tick.
If it is a lifter collapsing, the last thing you would want to do is readjust the valves, especially doing it the conventional way for hydraulic lifters. This could result in a bent push rod. Not to mention bad valvetrain angles which could cause further damage.
I do not typically recommend oil additives, but this may be a time to try what Duntov has recommended. If it does not work over the course of an oil change, it probably will not. If that does not work, it may be time to open up the engine and see what is going on.
Old Sep 9, 2008 | 07:18 AM
Duntov's Avatar
Banned
Merely changing the oil will not usually solve lifter "ticks". Isolating engine "ticks"to one side of the engine confirms that it isrocker arm noise caused by a sticking lifter.Often it is nothing but varnish causing the lifter to malfunction and the use of Schaler Risolone cansolve that problem.On the rare occasion that apressed-in rocker arm stud has pulled and is causing the lifterto havean insufficient amountof preload,and the rocker stud does not have to pull more than a few thousanths of an inch for that to happen, it will be necessary to remove the old rocker arm stud and install anoversize stud. That is why replacement pressed in rocker studs are only available ina oversize. Unlike adding Risolone to your oil to free a sticking lifter,replacing a rocker arm studrequiresspecial tools, and a special procedure that requires about 2 or 3 hours shop time. Therefore, itis not advisable for a part-timer to attemptto replace a rocker arm stud at home.
ALWAYS, try the cheapest solution to a problem first. People can are gouged by auto shops when theyanticipate the worst. Professional mechanics love it when customers do that.
postal0dude
Jul 13, 2012 11:30 AM
Kat
Dec 29, 2010 08:11 PM
762mm
Jul 15, 2008 02:47 PM
twitch
Jun 16, 2008 05:37 PM
Kenigan
Oct 24, 2006 04:37 PM
