what trans will work for 95 2WD 4 door blazer?
Old May 22, 2008 | 12:52 PM
jigsaw's Avatar
jigsaw is an unknown quantity at this point
Default what trans will work for 95 2WD 4 door blazer?
Hey Guys I have a 1995 2WD 4 door S10 blazer. It need the trans replaced. Do I have the 4L60E ? I need to know what all years and cars this transmission is compatable with. there is one for sale locally here is the info, I need to know if it will work or not?
For sale:
4L60E Automatic transmission set up from a 1999 Ram Air Trans Am with 66,789 miles on it and is guaranteed to work properly. This will fit a 1998-2002 V8 Chevrolet Camaro SS,Z-28, Pontiac Firebird Formula, Trans Am, or WS6.
Thanks for the Help Guys.
Michael
Old May 22, 2008 | 09:09 PM
Hanr3's Avatar
Default RE: what trans will work for 95 2WD 4 door blazer?
No that won't work for you.
Yes you have a 4L60E, however in '98 GM changed the tranny body. They made the bellhousing removeable and it also bolts to the oil pan. Your tranny doesn't bolt to teh oil pan. You will need a 4L60E from a '94-'96 I believe. Call you local salvage yard and they can hook you up.
Couple of side notes.
Clush teh rad and tranny cooler lines, ask your local autoparts for the product.
Add one quart of Lucas Tranny Fix if you swap in a used tranny. This will help the seals and what not deal better with teh new tranny fluid.
That's the short version, the why and how too's will have to be answered later. I have to go to bed now. 2:30am come mightly early.
00chevy
Apr 23, 2013 11:11 PM
lowloudnproud1
Sep 2, 2010 07:12 PM
chris015
May 27, 2009 11:10 AM
rob1621
Feb 29, 2008 08:15 PM
ERUKOLINDO
Aug 29, 2007 07:48 PM
