what year is this vortec from?
Old Jul 11, 2012 | 12:13 PM
stearnsm89's Avatar
stearnsm89 is on a distinguished road
Default what year is this vortec from?
I have a guy trying to sell me a vortec motor but it looks old,like from 1993-94.
How can i tell what year exactly its from or if it will work with my setup. Im trying to get away with less change over as possible id like to drop in and bolt if possible.
I have a 1996 jimmy awd slt.
here is the motor
Old Jul 11, 2012 | 12:18 PM
Thogert's Avatar
Yeah that's the 93-95 4.3 CPI motor.
Old Jul 11, 2012 | 12:21 PM
I'm going to go out on a limb and say you're not going to want to fuss with it.
It will be a somewhere close to a '94-ish motor given that it has an electronic EGR valve, but given the fact that it appears to have a metal timing cover, I'm guessing that it doesn't have provisions for the CKP sensor required for your ignition system among other issues as well.
Old Jul 11, 2012 | 12:25 PM
stearnsm89's Avatar
thanks guys i appreciate it
Thogert's Avatar
Oh, sorry, I didn't know there were any differences on the same style motor. My bad.
Old Jul 11, 2012 | 12:33 PM
'95s could have the old style vertical tower distributor cap which would not require a CKP sensor as well as the new EDI ignition system (horizontal terminal distributor cap) that does. In that case, the short block could be used as the CKP sensor would be present. The cam wouldn't be quite right for the SCFI upper end, but it would work. Heads on up would have to be swapped over.
Old Jul 11, 2012 | 04:23 PM
stearnsm89's Avatar
so would it be worth the swap? or should i just look for a newer motor? they wanted 425 for that motor. im finding newer motors for around 525 with around 115,000 on them. if i end up getting that newer motor what gaskets should i replace before i put it back in. im trying to avoid any leaks prior to putting the motor back in lol
Old Jul 11, 2012 | 04:49 PM
chris015's Avatar
ditch it,not worth your time.
My dads 92' has the metal manifold too. so it could be from a 92'+
Old Jul 11, 2012 | 06:45 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
my 95 has the Horizontal Cap so it's a 95 or older
Old Jul 11, 2012 | 10:34 PM
stearnsm89's Avatar
i appreciate it guys. so if i come across a good deal what gaskets should i replace before i attempt to put it back in? i was thinking valve cover, intake mani (possibly) front & rear main seal gaskets and a complete tune up before i drop it back in... any advice is appreciated guys. thanks again for everyones help
mrblonde108
Jul 17, 2017 07:52 PM
extreme
Dec 1, 2010 06:08 PM
debo42
Sep 14, 2009 06:34 AM
96blkblazer
Feb 26, 2009 04:29 PM
samuknow
Dec 12, 2008 02:14 PM
