When i try to accelerate, i seem's to lose power instead
Old May 22, 2006 | 04:02 PM
tidoux01's Avatar
tidoux01 is an unknown quantity at this point
Default When i try to accelerate, i seem's to lose power instead
Hi there
I'm working for some time on a problem on my truck. So i lose power on acceleration. I have change the fuel filter, the rotor, i'm going to change soon the spark plugs and the cable. Do you have some int for me ?
I'm waiting for every one !
Old May 22, 2006 | 04:24 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: When i try to accelerate, i seem's to lose power instead
Fuel pump? Is it original? It could be the cause...
Old May 23, 2006 | 09:54 PM
97blazer44's Avatar
97blazer44 is an unknown quantity at this point
Do you have any noise while you accelerate?
Old May 24, 2006 | 10:40 AM
When was the last time your truck has had a tune up (plugs/wires/cap/rotor)? I would atleast check the plugs to see how they are doing. Wires can be checked with a spray bottle of water at night. If you see sparks jumping from wire to pretty much any thing else, they'll need replacing. Also, the cap/rotor tend to foul up over time. If you were to pull off the cap, you could assess the condition of both the cap and rotor.
I would start there. It is never a bad idea to do a full tune up, especially if one has not been done.
Old May 24, 2006 | 06:42 PM
tidoux01's Avatar
Hi
I have change the rotor and will change this week the spark plugs and the cable. Hope it will come back good. But it seem's to be worst on rainy day, so i have to look for spark in the dark... ;-)
I will check tonight
Old Mar 5, 2007 | 02:57 PM
tidoux01's Avatar
Hi
I still have same problem. If i start the truck and don't wait a bit, i seem to have no power praticly. Everything goes back to normal after a few minutes. So if a start the truck with my remote starter and wait a bit i don't see the problem.
Any idea ?
Martin
Old Mar 5, 2007 | 07:07 PM
drperry's Avatar
You say you changed the rotor... But did you change the distributor cap as well?
If the problem goes away when it warms up, it could be the ignition module, or maybe an intake gasket... Is the computer throwing any trouble codes?
Jcog7293
Jan 31, 2020 09:53 AM
bear
Jan 5, 2010 02:51 PM
tomsblazer
Aug 20, 2007 01:18 PM
Whittaker
Sep 10, 2006 05:38 PM
