Where does this vacuum line go? Or is it suposed to be plugged?
Old Feb 19, 2008 | 08:45 PM
chevyman30571's Avatar
chevyman30571 is an unknown quantity at this point
Default RE: Where does this vacuum line go? Or is it suposed to be plugged?
Also where did you get pictures like those?
Old Feb 19, 2008 | 09:06 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Chevyman i sentchu a PM to your email...
Old Feb 19, 2008 | 09:22 PM
DlJr82's Avatar
DlJr82 is an unknown quantity at this point
ORIGINAL: chevyman30571
what do i have to get if the ball has has broken off? can i get the part at pepboys? Also is it bad if i have the hose plugged until i get the part? Also this is off topic of the vacuum line but i have what sounds like a lifter noise when the rpm's get around 2500 and higher. My mechanic said this is due to the engine having a solid lifter cam. But i dunno.
*Combining posts. Please use EDIT of no one has replied since your last post, thanks. TBB
I know you can't get the vacuum ball from Pepboys as I worked for them for a little bit, what i ended up doing was going to a junk yard and getting one there.
Old Feb 19, 2008 | 10:51 PM
Hanr3's Avatar
Where is that pic in realtion to the engine compartment?
I got a '00 and can go look if I know where to go look. [8D]
Old Feb 20, 2008 | 12:16 AM
On the driverside in front of the firewall. On my truck it is right infrom of my clutch master. So i would say driverside near firewall and fender.
Old Feb 20, 2008 | 11:13 AM
94blueknight's Avatar
94blueknight is on a distinguished road
lol wow a plugged vac line i had one of those when i bought my blazer it had a bolt in the end of it. when i found it i was like wtf!?! but i just looked around on the engine compartment for an opening about the same size that looked like it needed a line goin into it. i have a 94 so cant really help u out w/ the location.
Old Feb 20, 2008 | 09:38 PM
chevy lover awsome call dude thank you so much. I found it this morning. It was intact so i just reconnected it. thnks again.
liberatorx2
23
Oct 4, 2016 08:48 AM
er0ck273
May 14, 2016 07:07 PM
Little Roober
Dec 14, 2012 05:13 PM
Johnny Glenn
Feb 19, 2011 10:20 PM
willyman82
Jan 14, 2011 05:07 PM
