Where to find an engine oil dipstick
Old Dec 28, 2012 | 02:21 AM
chadmd80's Avatar
chadmd80 is on a distinguished road
Default Where to find an engine oil dipstick
Hey guys,
I can not find anywhere online that sells an oil dipstick for a 98 blazer ZR2. Anyone have any ideas on where to get one. The one that is in it has a yellow pull handle and is not the right one. It doesnt seal right and it reads about 4 inches above the max fill mark.
Thanks
Old Dec 28, 2012 | 06:23 AM
coolasice's Avatar
coolasice will become famous soon enough
Originally Posted by chadmd80
Hey guys,
Thanks
junkyard?
Old Dec 28, 2012 | 10:02 AM
El_Beautor's Avatar
Any Blazer would have the same dipstick. From '98 and up the engines are identical. No difference in engine between the regular Blazers and ZR2's.
Old Dec 28, 2012 | 12:00 PM
neo71665's Avatar
If I recall you have the aluminum oil pan. Any s-series 4x4 with an aluminum oil pan will work ( truck or suv).
There was only 4 different dipsticks for these things (with a 4.3).
Stamped steel
1) 2wd
2) 4x4
Cast aluminum
3) 2wd
4) 4x4
After that if it reads high then you are over filled.
Old Dec 28, 2012 | 08:56 PM
chadmd80's Avatar
Awesome, thanks guys, I will check the junkyard. I changed the oil. Put in 4.5 quarts and it reads 4 inches higher than the highest mark so I know it is the wrong one.
Old Dec 28, 2012 | 09:26 PM
On 4.3L Astro & Safari with aluminum oil pans, the dip stick is waaaaaay too long just an FYI when you go to the boneyard.
bjfrance03
Aug 16, 2012 02:57 AM
buffalorider13
Dec 6, 2010 11:36 AM
Trip..
May 18, 2010 06:31 PM
fruggy
26
Apr 28, 2010 08:18 PM
musclecar70sfan
Feb 22, 2010 11:16 PM
