Won’t shift out of first and mph gage don’t work
Old Apr 19, 2018 | 07:44 AM
Christian Wallace's Avatar
Christian Wallace is on a distinguished road
Default Won’t shift out of first and mph gage don’t work
I have a 99 Chevy blazer LT with a 4.3vortec and if I manually put it in first then shift up to 3rd but when I put in drive it shifts in back into 1st aw well the mph gage doesn’t work in not sure if it’s related or not but please help
Old Apr 19, 2018 | 09:53 AM
Transman304's Avatar
Does it have a check engine light on? If so you need to have it scanned for trouble codes.
Old Apr 19, 2018 | 11:13 AM
Yes the light is on and throughing a code for the speed sensor
Old Apr 19, 2018 | 08:47 PM
That would be a place to start by inspecting the wiring harness and connector. Also take a look at the fuses. Then try replacing the sensor. Good luck!
Old May 14, 2018 | 12:56 PM
where at in the harness do i need to look? i took the plug off an tested for continuity and it has it but haven't checked the other end of the harness and i searched for a speed sensor fuse but couldn't find one. i replaced the sensor still hasn't changed and still throws the code.
Old Jul 15, 2018 | 01:19 PM
Nick_200321's Avatar
Nick_200321 is on a distinguished road
Heyyyy so my 2000 jimmy is doing something very similar, by chance is you abs and parking brake light on? Mine did this and the first time once the speedometer started working and lights shut off it shift just fine. Now it just doesn't work. Just curious, did you ever fix your problem? I can't find what it is.
Jeffvader
Mar 7, 2019 09:27 AM
DavidSjr
Jul 19, 2018 03:49 PM
Daveed
May 29, 2018 10:23 PM
chevyjim
Aug 30, 2013 10:09 PM
XBlazer01
Jun 27, 2006 05:24 AM
