wont start at all
my 1996 blazer wont start it cranks but doent start its got good spark and good fuel pressure i replaced the icm crankshaft and camshaft and nothing rotor and cap were replaced 3 months ago but it just wont start on me it cranks but sometimes when i let go of the key like 2 seconds after it back fires sound like timing is way off i check spark and its fine well if someone had this issue please help me im going crazy with this issue thanksss
Haha oh yea...missed the first sentance apparently[:-]
So it ran fine after your rotor replacement? Have you tried pulling off the dist cap and checking the contacts? What brand of rotor did you use?
ok there's a problem with timing, timing is way off when it doent start, but when it does its fine but i replaced the icm and crank-sensor and still having same problem.. im thinking maybe the ecm????
