won't turn over......
Old May 20, 2009 | 06:27 PM
daBIGstuff's Avatar
daBIGstuff is on a distinguished road
Question won't turn over......
I have a 94 s10 blazer. it has the 4.3 vortec.
so i started it up one day and it started right up. it idled fine for a bit then just died. hit the key and it wont turn over..... i turned the engine back some and then hit the key and it turned over till it hit the same point and then stoped...
any ideas what it could be??
help please!!!!
Old May 20, 2009 | 06:59 PM
Pull your plugs starting with cylinder #6 (passenger rear). Report with what you find.
Old May 21, 2009 | 09:01 PM
daBIGstuff's Avatar
Pulled all the plugs and they seem fine
Old May 21, 2009 | 10:22 PM
mech cb's Avatar
mech cb is on a distinguished road
Maybe a piece in the distributor cap broke? That dont explain why it died after running though. It would just run rough, wouldnt it?
Old May 22, 2009 | 08:37 AM
Ok, so no fuel poured out which is a good thing. Is your oil level excessively high and does it smell like fuel?
Old May 25, 2009 | 08:30 AM
daBIGstuff's Avatar
Figured it out! Pulled the plenum and a fuel line cracked and was sprayin fuel into one of the ports. I pulled the plugs again and tried canning it and fuel pored out of the spark plug hole and now it cranks over again. All I need to do to fix it is get a new line.
Than for the help!
Old May 25, 2009 | 12:30 PM
Get the "nut kit" (as it is commonly referred to as) replaced and you should be good to go!
amp042
Jun 9, 2013 04:29 AM
bill62
Jan 30, 2010 06:42 PM
mkemu80
Jan 8, 2010 08:25 PM
pmezo
Dec 28, 2009 07:03 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
