worst news ever
Old Nov 4, 2009 | 07:41 PM
PFCBarner's Avatar
PFCBarner is on a distinguished road
I see your point !
Old Nov 5, 2009 | 06:20 AM
rastoma's Avatar
rastoma is on a distinguished road
Originally Posted by PFCBarner
I take it that maybe those words have been said before?
ABN31B got it right...
I was just having a little fun though
It just seemed as if the truck was in a junkyard that the disaster has ALREADY happened
I hope it does work out for you. Let us know if you get it cranked and going again.
Old Nov 5, 2009 | 03:44 PM
PFCBarner's Avatar
I will def post results ... right now im stuck in st louis airport ... tickets got all messed up 200.00 dollars later its all fixed and i dont leave till tommorow morn but i will get right to her as soon as i get home
Old Nov 5, 2009 | 04:27 PM
ABN31B's Avatar
ouch.... sounds like nothing is going right for you as of late. did you beat a black cat with broken mirrors under a ladder or something? Hope things start picking up again soon!
Old Nov 5, 2009 | 10:42 PM
old skool luvr's Avatar
hope your flight goes well.
good luck with cranking that 4.3 back to life.
Old Nov 5, 2009 | 10:47 PM
oktain's Avatar
Old Nov 6, 2009 | 06:43 AM
rastoma's Avatar
Old Nov 7, 2009 | 04:23 PM
PFCBarner's Avatar
Default Its alive!
so today i finally got to go work on blazer new starter new plugs and pb in the cylinders and it fired right up! it needs small things yet like i need to weld sway bar mount back on and theres a small trans leak from trans pan three bolts were loose maybe that was the issue ? Also theres a shutter when driving not real sure why maybe bad spots on tires from sitting any ideas would be great thanks in advance
Old Nov 7, 2009 | 04:40 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
So you didn't need the truck. But now you do? I agree on the oil. Marvel mystery oil would be the best
Old Nov 8, 2009 | 04:57 PM
PFCBarner's Avatar
NO vehicle was in junkyard because im in marine corps and was away so wasnt tryin to use it but now ill need it alot so it needs fixed any ideas on wheel shake ? its comin from right front starts at 65mph and up
