yay my turn more transmission issues. inputs!
Old Dec 25, 2011 | 05:30 PM
chris015's Avatar
Default yay my turn more transmission issues. inputs!
welp,for a while ive had a small clunk when applying throttle on the interstate. now its gotten alot worse. trans shifts fine,but when going say 60 mph and i tap the throttle i hear and feel a clunk. motor mounts and trans mounts are fine. i wish it was something that simple.
Another thing is the rear diff. when i replaced the u joints on the driveshaft i noticed ALOT of turning play. (as in the shaft would turn 1 1/2 inches or so before the wheels would turn).
It'll clunk when put into reverse too at a stop.
What hard components in the trans (700r4) will cause it to clunk? I doubt another fluid change would help if its a hard part. fluid level is fine. did a pan change on it back in july.
Old Dec 25, 2011 | 07:09 PM
xgiovannix12's Avatar
sounds like they gave you the wrong joints
is there any play in the joints them selfs ?
Old Dec 25, 2011 | 07:26 PM
chris015's Avatar
there is no play between the joints,theres play within the rear diff. I need to find out how much lash is acceptable.
chris015's Avatar
John i bet 99% you slept in the wrong position. happens to me all the time.
Old Dec 25, 2011 | 07:47 PM
ohh i misunderstood sorry
i think i had to much wine any ways
yea i must of its been killing me all day
warthogdriver
Sep 4, 2013 12:10 PM
chris015
Aug 17, 2011 09:10 PM
dougs10
Dec 14, 2010 03:24 PM
Dory
Aug 11, 2006 06:34 PM
blazerscooby
Feb 21, 2006 10:14 PM
