1990 k5 blazer 5.7 idle issue
Old Sep 22, 2014 | 02:54 PM
Randomtask2's Avatar
Randomtask2 is on a distinguished road
Default 1990 k5 blazer 5.7 idle issue
Hello again, So I'm temporarily stumped. My k5 will not idle without giving it gas. Idle air control valve replaced and connector, new fuel injectors, timing Is perfect, Drives perfect. Until you come to a stop then dies out. I am stumped. Any information will help thank you.
Old Sep 24, 2014 | 03:51 PM
jpimp's Avatar
jpimp is on a distinguished road
any codes?
when was tune up last done?
Old Sep 26, 2014 | 11:31 AM
Originally Posted by jpimp
any codes?
There is no codes at all. Don't know the last time the tune up was done. But the plugs and wires don't look to be in that bad of shape so im assuming not too long ago. But im kind of ruling out spark being the issue. Because at high rpm she runs awesome no miss, no stumble, she doesn't skip a beat. This is only idle. Next on my list of possible causes. Because I need to give it gas to start it. Not getting enough fuel. Maybe the fuel pressure regulator. Next day off I will replace that.
Old Sep 27, 2014 | 10:13 AM
abig84's Avatar
check your egr valve. if they start to stick wide open they will cause a heck of a vacuum leak and cause your truck to die out, bypass it or block it to see if it fixes your problem.
it kinda looks like this
Old Sep 28, 2014 | 12:26 PM
The Egr valve is closed at idle and I checked to make sure it isn't frozen it moves freely.
Old Oct 1, 2014 | 12:56 PM
Well 90% of the time we don't check the most basic stuff 1st. It was a PCV valve no joke a 5 dollar fix lol
Old Oct 1, 2014 | 01:42 PM
HARDTRAILZ's Avatar
HARDTRAILZ is on a distinguished road
At least it was not expensive and its fixed!
Old Oct 2, 2014 | 02:11 AM
I cant tell you how shocked I am that it was that simple. lol
Randomtask2
Dec 24, 2018 10:22 AM
BOBOtheblazerguy
May 31, 2012 05:06 AM
wollefdoog
Oct 27, 2011 11:13 PM
tjf76
Jul 10, 2009 07:26 PM
the fuel
Engine & Internal
Dec 15, 2005 01:25 AM
