383 vs. 350
Old Dec 30, 2011 | 07:48 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default 383 vs. 350
hey ive been looking around at remanufactured 383's what are the main advantages of haveing one of these as far as a mud truck goes ..i cant find a clear side by side of the hp/tq between a 350 and a 383 i would like some more power but is it woth the cash?i got a crate 350
SPECS:
Horsepower: 375
Torque: 420
Fuel: 89 Octane
Crankshaft: Scat 9000 Steel
Pistons: Speed Pro Hypereutectic Graphite Coated (Flat Top)
Cam: Flat Tappet (.475 Lift & 218/218 Duration)
Heads: 624 or 882 Cast Heads
Valves: 1.94/2.02 - SBI
Bearings: Clevite 77
Rods: Powder Metal HD GM
Rod Bolts: ARP
Block: 4-Bolt Main
Flywheel: Included
Flexplate: Included
Intake Manifold: Professional Products or Edelbrock
Balancer: Included
Timing Cover: Included
Oil Pan: Included
Valve Covers: Included
Gasket Set: Included
Core: Exchange or 350
Warranty: 5 Year/50,000 Mile Nationwide
Old Dec 30, 2011 | 09:31 PM
AJBert's Avatar
As the old saying goes, there is no replacement for displacement.
That is about the only advantage.
Rather than looking at the cubic inches, look rather at the power curve and figure out what you need for mudding. Torque in the lower end or hp in the upper end?
Old Dec 31, 2011 | 08:46 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
a 383 is just a built 350 rite? just different internals? 383 is gonna give u more snap and possibly more punch but the 350 is gonna run smoother and all around better. id stick to the 350 for a mud truck. ul have less issues with heat and such. but im partial to them 350s. u just cant beat em.
Old Dec 31, 2011 | 12:19 PM
neo71665's Avatar
383 is a 350 with 400 crank. 383s produce much better torque in a wider range. For a mud truck either will work fine. Personally I would take a 383 over a 350 any day of the week.
A 383 built right will not run any rougher or hotter than a 350. I had a 383 in a reg cab s-10 street truck and it cooled just fine. I did have a bigger cam than the 350 I pulled out so the lope was teeth rattling.
88s10Blazer
Dec 22, 2009 05:50 AM
86 like me
Engine & Internal
Sep 17, 2008 02:30 AM
dimmuborgir6nik6
Mar 9, 2008 04:28 PM
sumner
Engine & Internal
Apr 30, 2007 05:15 AM
SniperX13
Engine & Internal
Oct 22, 2006 09:23 PM
