4 in suspension lift questions (skyjacker)
Old Oct 26, 2010 | 07:07 PM
83k5blazer's Avatar
83k5blazer is on a distinguished road
Default 4 in suspension lift questions (skyjacker)
im about to get a lift. its a 4 in skyjacker with spring all around. My Question is. do i need all the extra parts they are trying to sell me.
Example do i need the, Transfer Case Lwrg Kit, Gm Adjustable Drag Link 4"Offs,
Steering Arm 67-87 Gm W/4
i will buy the Dual Stabilizer Kit
but do i really need the other stuff. im new to lift kits, any feed back will be help full thanks.
Old Oct 26, 2010 | 08:12 PM
The transfer case lowering kit will help keep your drive shaft angles ok, but I don't know that it is completely needed.
The adjustable drag link & drop steering arm are more necessary to keep from getting steering bind when flexing the suspension.
I would recommend getting the whole kit. Having only pieces will make it more difficult to get tech help out of them.
Old Oct 26, 2010 | 09:29 PM
83k5blazer's Avatar
thanks for the info swatrlkk i dident want to spend the extra cash, but i do want to do it right. so ill get the hole kit thanks
Old Dec 14, 2010 | 01:14 PM
IrvJr's Avatar
IrvJr is on a distinguished road
The drop drag link from them is garbage. Mine didnt last 2 months. I put a raised steering arm on and used Napa brand drag link which are HUGE and it works much better. I plan to use NAPA's steering parts to replace all my loose tie rods too and make her nice and tight. I did use the longer braided brake lines and they helped the pedal feel and worked much better.
xJakeLIKEShisBLAZERx
Oct 21, 2011 05:11 PM
ericthughes
Sep 23, 2010 07:24 PM
94blueknight
Lifting Tech
15
Sep 30, 2008 06:14 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
