4x4 help
Old Sep 26, 2010 | 12:57 PM
83k5blazer's Avatar
83k5blazer is on a distinguished road
Default 4x4 help
so i was out bird hunting at the ranch. it was a little muddy so i shift into 4 hi and make it past so i shift out back to 2wd and dose not shift out of 4 hi any one know what may cause this.
its a stock 1983 chevy 4x4 k5 blazer 305ci, auto trans (overdrive), auto locking hubs i have used the 4x4 a few times and it never gave me any problems till now.
thanks for the help
Old Sep 26, 2010 | 08:16 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
shift to neutral then to 2hi? try backing up 15ft or so?
Old Sep 26, 2010 | 09:59 PM
83k5blazer's Avatar
i tried backing up and it still wont shift out. i try again tomorrow. thanks
Old Sep 27, 2010 | 01:36 PM
83k5blazer's Avatar
Still won't shift out of 4hi?
Anyone?
Old Sep 28, 2010 | 08:00 PM
abig84's Avatar
is the lever just stuck or moving and not coming out of 4x4?
look at the shifter lever on the side of the transfercase and see if its screwed up somehow. i had a daily driver blazer a while back that was really stiff. you had to stand on the lever to push it back to 2wd
Old Sep 28, 2010 | 09:49 PM
83k5blazer's Avatar
The 4x4 shifter is going into 2wd but its not shifting out of 4hi. Today i removed the adjustable 4x4 link-edge and made sure it shifting through 2wd, 4hi, neutral, and 4lo. put it back together still nothing.
when in 2wd is the front driveshaft free or does it have resistance.
dose anyone have a 4x4 vacuum diagram
Old Sep 29, 2010 | 10:30 PM
abig84's Avatar
if its a k5 blazer theres no vacuum like the s10s. the lever engages the driveshaft to the front axle and the hubs lock the tires to the axle. when driving it shouldnt be locked BUT you said you have those autohubs ive seen it where you turn the driveshaft and those things engage they are unpredictable and fail at the worst time.
Old Sep 30, 2010 | 08:17 PM
83k5blazer's Avatar
thanks abig84 it was the auto hubs. bought some warren manuel hubs today put them on and bingo it worked. just have to get off to lock them. when i want to play.
Thanks for the help everyone
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
