87 k5 blazer no cat converter
Old Mar 23, 2008 | 08:35 PM
mikeymace's Avatar
mikeymace is an unknown quantity at this point
Default 87 k5 blazer no cat converter
I been working on a 87 k5 blazer.5.7 l,700th tranny..I have no catalytic coverter in the truck,it was bought that way..Is there any tips anyone out there can give me to make the truck run better? I recently changed out the fuel pump and the radiator cooling temp sensor which made a big dfference in cold starts..But when the engines cold it seems kinda shakey till the thermostat kicks in then it settles down..Is this normal?Any help will be greatly appreciated!!
Old Mar 23, 2008 | 09:56 PM
Default RE: 87 k5 blazer no cat converter
*Moving to Fullsize Tech*
I'm betting that it doesn't have the heat riser in the passenger side exhaust tube. The heat riser was a thermo-spring controlled restrictor valve that accellerated the warmup of the engine by restricting the exhaust flow.
babeba67
Oct 17, 2011 08:27 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
