88 k5 flywheel noise
Old May 15, 2011 | 08:03 AM
deathman's Avatar
deathman is on a distinguished road
Default 88 k5 flywheel noise
i have a 88 blazer 5.7 tbi ,700r4 trany . i noticed some noise under the truck , sounds like its comming from the torque coverter , i pulled the inspection plate and noticed my flywheel has a wobble to it , the truck runs pretty good but lacks power , could this noise get picked up by the knock sensor and retard my timing ? also what else could be making that noise? torque converter,flywheel, trany pump ? torque converter bolts r tight , the flywheel wobbles but not the converter, any help or ideas would b helpfull thanx
Old May 15, 2011 | 09:01 AM
Could be a warped or cracked flex plate. A noise from the flex plate could be picked up by the knock sensors.
Old May 15, 2011 | 09:03 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
i would start with a flywheel i dont think there supposed to wobble
Old May 17, 2011 | 01:05 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
No they're not. Also check for loose bolts and oblong holes if the bolts are loose as well as the aforementioned cracks. Had a 82 2WD truck with this problem.
BlazerSS
Detailing
Mar 17, 2009 10:18 PM
jonesjamesw
Apr 28, 2008 09:55 PM
jonesjamesw
Mar 28, 2008 06:33 PM
tom1337
Nov 10, 2007 12:18 PM
mars004
Jan 22, 2007 10:00 AM
