89 K5 Blazer low idle/ surge problem
Old Feb 23, 2009 | 09:57 PM
doop300's Avatar
doop300 is an unknown quantity at this point
Default 89 K5 Blazer low idle/ surge problem
Ok heres the story, had a low idle and it would sometimes stall and die at a stop and while driving it would kinda surge or pulse up and down which felt like someone bumping into you constantly.
So i replaced the tb gasket and put a new fuel presure regulator kit on it. the old kits spring was rusted in two and looked really bad. Now when I drive it I can still very slightly feel the same pulse or bumping, its faint but still there. What should I do next? maybe buy an entire new regulator? or do i need new injectors?
It still wants to die at a stop as well. Not sure why.
Any help would be great
Thanks
Old Feb 24, 2009 | 06:35 AM
Default RE: 89 K5 Blazer low idle/ surge problem
I would remove and clean the EGR valve. It is possible that it is leaking past, giving you inconsistent O2 sensor readings.
Old Feb 24, 2009 | 12:39 PM
doop300's Avatar
Which one is the EGR? Im new to the tbi system.
Old Apr 11, 2010 | 02:21 PM
killer_illusions's Avatar
killer_illusions is an unknown quantity at this point
egr is the funky lookin thing bolted directly to the passenger side of the intake slightly behind the tbi that has a single vacuum line runnin to the little 3 pack of sensors on a bracket
jdiaz
Sep 26, 2023 11:29 PM
R.Daughtery
Sep 29, 2013 02:31 PM
sxtreborn
Sep 24, 2012 09:32 PM
johnalgood25
May 24, 2011 09:39 AM
dannyv
Feb 24, 2011 06:12 PM
