89 K5 gas flooded motor
Old Jun 10, 2010 | 03:52 PM
  #31
Ck1500's Avatar
Ck1500 is on a distinguished road
Originally Posted by Thid92
seems as I had a slight leak in the heatercore and had leaked some antifreeze, I topped the truck off and didnt get the check engine light to come back now my only problem is that I am only getting roughly 8 miles per gallon lol but the truck runs good. I am going to pull the battery to reset the code in my computer to see it will better my gas mileage.
yeah 8 seems pretty low unless your hubs are locked or something like that.. i was averaging about 12-15 with mine.. sitting on 33x12.5.15 tires to boot. make sure you dont have anything dragging, for example if someone did a rear brake adjustment. theres a chance its set to tight. also blazer calipers on the front are notorious for not lasting as long as they should. if you have the Auto Hubs on the front axle. that could be a problem area also.. or if its switched over to a manual lock out.. make sure there set to free otherwise your pushing the axle/gears etc.. reseting code might take care of it also!!! also might want to make sure everything is greased... and that all fluids are in good shape. like diffs, and transfer case, tranny , engine oil etc.. if i remember correctly you said it had a crate motor, this might play a effect also.. if it has more ponies then stock theres a chance you might be stuck with a 8 mpg truck also..
hope this helps
Ck1500
Old Jun 10, 2010 | 05:11 PM
  #32
Thid92's Avatar
Thid92 is on a distinguished road
well swapped out the heatercore along with the knock sensor, pretty sure it is just a stock crate motor and no extra HP going to reset the code and see if it helps. Also I have the 700R with overdrive but still seems to average 8 mpg on the thruway.
toaks1
Aug 20, 2012 08:14 PM
jettmech2002
Sep 26, 2009 11:59 AM
Quicksilver
Oct 11, 2008 02:44 PM
N.alaska_blazer
Sep 22, 2007 11:00 PM
