Another Vibration Thread
Old Jun 16, 2011 | 08:15 PM
educky's Avatar
educky is on a distinguished road
Default Another Vibration Thread
I have a few issues left on the vehicle, check engine light, which after I got my factory service manuals I was able to decode by shorting 2 pins on the header you plug into, god I love older vehicles... looks like a oxygen sensor.
Anyway, So the vibration Notice it at higher speeds, and only when I step on the gas, constant vibration. I let off the gas and it seems to go away, so Im thinking mebbie a driveline, or ujoint issue? Anyways I was wondering... could I remove the rear drive line, and run in 4wd (so only the front would work) and see if the vibration goes away? or is that a nono
If its ok, is it hard to do? Any precautions?
Old Jun 27, 2011 | 04:35 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Sounds like pinion bearing in rear end is going out. I just went through this issue on my 1988 Blazer. Could also be the u-joints too. Put the truck in park, go underneath and see if you can move the rear driveshaft. If you can, you most likely need u-joints, but I think your problem is in the rear differential.
Old Jun 30, 2011 | 02:16 PM
educky's Avatar
It was the U joints, it had the factory ones on there, 210,000 miles were not kind...
Now I got another issue =) I just step on my pedal a little bit to say 30mph, and keep it there, its like the engine gets quiet and loose power, stomp on the gas and it comes back for a little bit then same thing.
normal things done so far, injector cleaner, plugs, fuel filter, since the u joints were original, I wonder if the exhaust is, Im hoping its a collapsed Cat converter, because if its not, im looking at engine issues =(
Old Jun 30, 2011 | 10:18 PM
Glad you got your issue fixed. As for the cat converter theory, does your transmission shift a little late or a little off? If yes, this would confirm a clogged cat. Also wondering when was the last time a tune up was done on your truck?
Old Jul 1, 2011 | 12:29 PM
xtremepbma's Avatar
xtremepbma is on a distinguished road
I had the same problem. Spark plugs were gapped incorrectly. I'd check those. .035 is the correct gap
wlorton
Lifting Tech
Jan 26, 2010 12:28 AM
02 Vortech
Nitrous, Super Chargers, & Turbos
Oct 13, 2008 07:38 PM
ksibley603
Jan 9, 2008 10:11 PM
miso
13
Jan 2, 2007 10:20 AM
okmomw/blazer
Jun 30, 2006 01:26 AM
