Anyone use a powertrax
Old Jan 26, 2007 | 05:25 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Default Anyone use a powertrax
Anyone use a powertrax or similar locker in their open carrier? Hows it work, any complaints? How hard was it to install? How long did it take?
Old Jan 27, 2007 | 12:52 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Anyone use a powertrax
I have installed a couple of these, they are really easy to install. It works like a factory limited slip, though a little more noisy, not bad though. It took about as long to install as new spider gears are to install. I have been thinking about doing this to mine lately!! Korey.
Old Jan 27, 2007 | 01:23 PM
alamantia's Avatar
If I remember correctly, the cross pin gets installed through teh center of teh spider gears, so once you remove the cross-pin retainer bolt, slide out the cross pin, push in the axles, remove the c-clips, remove axles you can just pry one spider gear out and since teh axles are removed the other three will just fall out right?
Then the install should just be following directions from there I assume, it looks easy enough, and since I have a quiet rear now andthere will be no removal of the carrier (which is a huge benefit) thats about all you have to do,am I correct? If so I can even do it at home with no special tools, just like the ad says...
Old Jan 27, 2007 | 02:40 PM
Kordog's Avatar
Yup, That is about it, but after you have the axles out you just rotate the spider gears out, no prying needed!! Korey.
newguy
Mar 22, 2013 09:36 AM
rodono
Performance & Brainstorming
May 14, 2011 06:11 PM
KM346
Jan 23, 2011 09:12 PM
JODYM
Jan 15, 2009 06:48 PM
zero psi
Feb 20, 2007 08:56 PM
