atf in the engine compartment
Old Jul 8, 2015 | 12:38 AM
Matthew Burr's Avatar
Matthew Burr is on a distinguished road
Default atf in the engine compartment
Hi everyone, i'm new the the K5 blazer, but i'm fairly experienced in engine work.
I purchased an 89 blazer with the 350 and a rebuilt 700r4 transmission. i was driving it the other day in 90 degree weather for about an hour and shortly after i stopped to hook up to a small trailer i was having a real hard time engaging reverse. then i noticed some smoke from the hood and a trail of fluid. turns out a bunch of atf shot through the engine compartment. I've done some reading but would like some opinions. I had to drive it a cpl hundred feet in order to get out of the way of a trucking business asap and it didnt sound too healthy. am i screwed, or should i be ok if i find the cooling hose leak and replace it?
Old Jul 9, 2015 | 05:45 PM
chris015's Avatar
Ok,sorry to sound stupid but i am when it comes to full size blazers. if you look above your transfer case you might see a sensor with some rubber vacuum lines. when the sensor fails the fluid gets sucked into the lines at the engine compartment and sometimes ac. it may have got sucked up and you might had a vacuum leak and it blew all over in the engine compartment.
If you do have that sensor, i cant find a part number,but take it off and bring it with you to the auto store.
Old Jul 9, 2015 | 06:10 PM
abig84's Avatar
k5s dont have any kinda vacuum lines going to the transfercase like a s10 or other newer trucks would. everything is engaged manually or auto hubs up front i guess if that counts. most likely its a transmission cooler line as thats really the only reason trans fluid would be up under the engine as it runs from the trans to the radiator.
i would also think maybe its power steering related as a lot of people put trans fluid in there but if you are having reverse issues, yeah probably a transmission line
Old Jul 10, 2015 | 10:56 PM
thanks for the posts, but before i even start to work on it, i was hoping for opinions on weather i screwed the transmission by moving it after that happened
Old Jul 12, 2015 | 09:01 AM
abig84's Avatar
for that short of distance, probably not. cars get towed in all the time with blown trans lines or no fluid and a repair and refil of fluid fixed the issue if the truck drove for a while slipping or you let idle for a excessive amount of time then maybe
ktryan
Sep 24, 2009 05:28 PM
macdaddy25177
Jan 14, 2009 12:38 PM
GABlazer92
Mar 24, 2008 12:26 AM
nflea7
Aug 14, 2007 12:36 PM
thanser
Jan 28, 2006 08:50 PM
