General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Engine Compartment Light
Old Jan 28, 2006 | 08:09 PM
thanser's Avatar
thanser is an unknown quantity at this point
Default Engine Compartment Light
That's a handy light under the hood, near the trailing edge. But mine isn't working.
The lamp is good, I checked it with a multimeter.
Is there a mercury switch that activates it when the hood is up? Where is it located?
Easy to fix this? Has anyone ran into this problem?
Thanks!
Old Jan 28, 2006 | 08:31 PM
4lowlife's Avatar
Default RE: Engine Compartment Light
Yes there is a merc switch. I think its inline where the bulb goes.
Did you know they are supposed to be removed before a car is scrapped/crushed? It is a known heavy metal. Like Megadeth.
click here for a PDF on location on merc switch location and removal. I just found it.
Old Jan 28, 2006 | 08:39 PM
thanser's Avatar
So, if the light doesn't come on, I'm to assume the whole lamp socket needs to be replaced?
It's not on its own fuse, is it? I wouldn't think so.
Thanks!
Old Jan 28, 2006 | 08:42 PM
4lowlife's Avatar
With the hood up, obviously, stick a multimeter in the bulb hole (volts dc,) and see if you get any voltage readings.
Old Jan 28, 2006 | 08:50 PM
thanser's Avatar
It was hard enough to get the bulb out and then in again, but I'll give it a shot.
I might have to take the bulb socket off the hood to make the correct contacts.
But, YES, it might be easier to do this with the hood UP...!
Sunfish
Feb 7, 2015 01:14 PM
Kyle_Richard
Jan 3, 2012 08:56 PM
macdaddy25177
Jan 14, 2009 12:38 PM
GABlazer92
Mar 24, 2008 12:26 AM
nflea7
Aug 14, 2007 12:36 PM
