Blazer not running fuel issue?
Old Feb 26, 2011 | 10:16 PM
Another possibility is that the float inside the carb is malfunctioning.
Old Feb 26, 2011 | 10:26 PM
TheK5's Avatar
TheK5 is on a distinguished road
My first old vehicle. I'm clueless, but slowing learning. What do you think about sticking a pressure guage in fuel line before carb?... Hopefully to find out whether it's before carb or the carb.
Old Feb 26, 2011 | 10:45 PM
You could test the pressure. You are looking for somewhere between 6 & 8 psi.
Old Feb 26, 2011 | 10:49 PM
TheK5's Avatar
I do not have a tester.... I figured cheaper to buy just a gauge lol...
Old Feb 26, 2011 | 10:54 PM
A gauge will work. That's all that is used to test fuel pressure.
Old Feb 27, 2011 | 05:27 PM
TheK5's Avatar
update
replaced metal fuel line with rubber line and inline fuel gauge. Is it normal for a fuel gauge to bounce super fast? (0-4 just back and forth) It's bouncing to around 4 lbs.
I swapped line on pump..... there were correct because it ran out of gas lol.
Before putting back on pump I pump air with the compressor to line and blew back into the tank. Runs a lot better but still hesitating. Fuel up to around 8 lbs still bounces steady.
Problems obviously in the tank.. what do you think? Currently I have about $100 in the tank I hate to drain it
Old Feb 27, 2011 | 05:38 PM
It is normal for it to bounce with a diaphragm style pump which is what you have. Each revolution of the cam causes the pump push rod to push on the diaphragm arm which pumps fuel.
0-4psi sounds a bit low, but 8psi is good.
Have you considered tearing down the carb and rebuilding it?
Old Feb 27, 2011 | 07:09 PM
TheK5's Avatar
Just drove about 5 miles... It's driving fine... BUT idle it's rough and wants to die. When I returned home 3 psi again.
I have never done it before. I suppose I could bring in house and tear apart.
Old Feb 27, 2011 | 07:13 PM
If it drives ok and only the idle is crappy, that sounds like a carb issue.
Is it the factory carb, Rochester Quadrajet?
Old Feb 27, 2011 | 07:16 PM
TheK5's Avatar
You know, I just bought it last month. I have never owned anything carbed. lol, I just need to do some reasearch once it's out. I have no idea what kind of carb it is. It's black as **** from gunk
