brake pulling to one side
Old Mar 25, 2008 | 11:40 PM
1989blazed's Avatar
1989blazed is an unknown quantity at this point
Default brake pulling to one side
Ok i know i have asked a lot of questions lately but i just got this blazer and I love it! I have been ripping it apart trying to fix everything. Ok heres my question when i step on brakes truck pulls hard topassengerside. it has new pads and i even replaced the driver side caliper thinking that was the problem and it is still pulling hard to pass side. Any suggestions?
Old Mar 26, 2008 | 06:33 AM
Default RE: brake pulling to one side
A pull could be caused by a problem with the front and/or back.
From your other thread, it sounds like the problem wasn't there before the pad replacement. Did you replace the caliper at the same time? Did you have the rotors replaced or resurfaced? When you replaced the caliper, did you fully bleed the air from the system?
Old Apr 3, 2008 | 12:34 PM
alamantia's Avatar
alamantia is an unknown quantity at this point
Did you replace the brake hose going into the caliper?
Old Apr 9, 2008 | 01:15 AM
BigBlack73's Avatar
BigBlack73 is an unknown quantity at this point
My Blazer did the same exact thing, to the passenger side. i hadn't touched my front brakes since i got the beast, but i went and bled both front brakes and the pull pretty much disappeared after that so i'd greatly consider kyle's thoughts on this.
porshapower
Aug 1, 2013 09:58 PM
97Beater4WD
Mar 24, 2012 03:46 PM
Wexinlo
Apr 6, 2011 11:35 PM
roadkill
May 15, 2010 07:19 PM
1989blazed
Mar 26, 2008 06:00 AM
