Building blazerstien
Old Oct 12, 2009 | 11:09 AM
Eddie Powers's Avatar
Eddie Powers is on a distinguished road
Smile Building blazerstien
I have 93 fullsize blazer that I'm wanting to add a 5.3 and a 4LE65E. Need info on aftrmarket wiring harnesses to make it operate correctly. Also trying to add transfercase. Would also need some proper measurements to install engine/trany/transfercase.
Old Oct 12, 2009 | 12:35 PM
You are going to be custom here. The 5.7L TBI motor and 5.3L LS based motor have really nothing in common, control wise. Wiring will be completely different as will the PCM to control the new mix. If you get the drivetrain from a newer truck complete (including the wiring harness and PCM), you should be all set to graft things together.
I am not sure why you would want to go to the 4L65E. If you were going to be swapping out to something different, why not go straight to the 4L80E and be done with it.
Unlimitedsp
Jan 14, 2010 03:51 PM
alphawhisky
Jan 14, 2007 12:16 PM
88s10Blazer
Sep 22, 2006 02:36 AM
Hanr3
Jul 26, 2006 12:27 AM
jagblazer01
Mar 15, 2006 07:58 PM
