clunk
Old Jul 23, 2011 | 04:16 PM
89stlblazer's Avatar
89stlblazer is on a distinguished road
Default clunk
theres a loud clunk when i put it in reverse like its engaging real hard what would cause that
Old Jul 23, 2011 | 04:42 PM
chris015's Avatar
Either its bad u-joints,rear end,or trans. Check the u joint for wear/play 1st before anything. if that turns out good,jack truck up,add safety jacks,remove the driveshaft. then reinstall it to the rear diff only. turn the driveshaft back and forth to see how much play you have before the wheels move.
Old Jul 23, 2011 | 07:51 PM
i just replaced the back u joints could it be the front ? also its a diff trans and rearend
Old Jul 24, 2011 | 09:26 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Check transmission linkage, and I would pull off the rear differential cover and see how the gears look in there. Plus it wouldn't hurt to change the fluid.
Old Jul 25, 2011 | 08:42 PM
ill check and get back to you
choover82
Jan 14, 2012 01:02 PM
Wxman2000
Aug 11, 2007 03:48 PM
raviz
Nov 21, 2006 09:54 AM
mikol23
Engine & Internal
Sep 28, 2006 01:01 PM
fenderfree
Dec 14, 2005 09:04 PM
