confused about radiator problem?
Old Jul 20, 2010 | 08:57 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default confused about radiator problem?
hey i keep filling up my radiator with coolant and theres a hose going to an overflow tank on the passenger side of the truck right next to the radiator ...but my radiator keeps getting low and the plastic tank keeps filling up is it running hot or is something else wrong?(im changeing the temaopture gauge sending unit in the next day or so )
Old Jul 21, 2010 | 05:18 PM
abig84's Avatar
You can try replacing the radiator cap too
Old Jul 21, 2010 | 10:15 PM
i have whys it draining into that container?
Old Jul 22, 2010 | 06:08 AM
A weak cap will push radiator fluid into the overflow reservoir. Replace the cap and see if the problem persists. If it does, it could mean that you still have air in the system
Old Jul 22, 2010 | 07:19 PM
yeah i kinda bent up the brass around the radiator cap and when it was getting smoggged on the dyno it lost all the fluid out the top and i got a new cap but maybe ehre the cap screws on to the radiator is bad ghow could i tighten that up without gettin a new radiator.....if i do have air in the system how would i test that out it says its holding pressure ...could air in the system make it overheat or would i just go through alot of radiator fluid?
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
bigdaddykane93
Jan 4, 2010 12:03 PM
chiefbong360
Jan 4, 2010 10:27 AM
chevychic4life
Engine & Internal
16
Mar 28, 2006 04:29 PM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
