DEAD 1990 Full size (350c.i.)
Old Aug 23, 2009 | 03:15 PM
kevin d's Avatar
kevin d is on a distinguished road
Default DEAD 1990 Full size (350c.i.)
Ran fine. Starter arced, replaced. Ran fine, then cranks but no run. Tested> weak or no spark, AND injectors not pumping ((Fuel pressure great @ throttle body.))
--Replaced Ignition Module (under cap) -old one tested fine but repl. anyway.
--Bought pickup coil> but havent installed yet. DONT WANT TO KEEP THROWING $$$ AND/OR TIME INTO IT.
>>>>>>>ANY SUGGESTIONS APPRECIATED<<<<<<<<
Old Aug 23, 2009 | 03:33 PM
Did you have the coil tested?
I have seen a bad ESC (electronic spark control) module cause a similar issue (weak spark and no power to the injectors).
BTW, I have moved your post into the appropriate section. Please try to post questions in the tech sections relevant to the vehicle and/or type of problem you are working with.
Old Aug 26, 2009 | 08:21 PM
t.lyttle's Avatar
t.lyttle is on a distinguished road
the ESC went out on my 1990 K5 and once i replaced that its ran awsome ever since
bryson_horton
Nov 3, 2011 10:23 AM
acc62001
Jul 21, 2011 07:20 AM
unclecbass
Jun 28, 2011 05:27 PM
bryson_horton
Mar 3, 2010 08:22 PM
Drumer73
Mar 1, 2009 06:19 PM
