Door Lock Cylinder
Old Apr 22, 2009 | 06:02 PM
bigfdaddy's Avatar
bigfdaddy is on a distinguished road
Unhappy Door Lock Cylinder
I own a 1993 full size blazer. All 3 of my door lock cyclinders are completley frozen. I have tried wd-40, graphite lube. Driver side door locks and unlocks but key wont work. passenger side door wont lock. rear tailgate door will unlock window only by tailgate release.
HOW IN THE HECK DO I REMOVE THE CYCLINDERS TO REPLACE THEM?
Old Apr 22, 2009 | 06:09 PM
oisinirish's Avatar
I would imagine on the front two doors you need to remove the interior door panel and wind insulator, or whatever it's really called, and you can get to the back side of the cylinder from there.
On the tailgate, pretty much same thing. There should be an access panel on the inside of the gate, probably buried under carpet or whatever you have on the interior side of your tailgate. The cylinder itself should have a locking clip, similar to a snap ring or e-clip to allow for removal.
Check out http://WWW.LMCTRUCK.COM, the catalog has an exploded view of lock cylinder for the tailgate.
Old Apr 22, 2009 | 06:20 PM
The doors are easy. There is a spring clip which holds the lock in.
The tailgate is another story. You need to remove the whole rear window crank (manual rear window) or the chrome power window handle. That piece is bolted on from the inside.
Old Apr 23, 2009 | 10:48 AM
bigfdaddy's Avatar
how do u remove the clip for the door lock. i got as far as being able to pull handle out some what. on the back of the lock the linkage arm whont allow me to pull handle out. the little tab the linkage goes into is in the down position i beleive. i removed the linkage that goes to the lock its self and removed clip the holds linkage. but i cant get clip off back of cyclinder as it rusted all to crap.
Old Apr 23, 2009 | 11:14 AM
The rods inside have spring steel retainers. You have to rotate the retainer off of the rod and then you will be able to pull the rod out. From there, you will see the U shaped spring clip that holds the lock onto the door.
Old Apr 24, 2009 | 09:17 AM
bigfdaddy's Avatar
i was able to get the lower rod off. but as far as the clip for cylinder i cant seem to either find it or its rusted with the rest of the mechanism i cant see inside there to tell where it is. i took all the door panel off except for the black metal piece. i unscrewed the handle and was able to pull handle almost all the way out but the arm is locked to where i cant finish pulling handle out of door.
Old Apr 24, 2009 | 06:17 PM
Do yourself a favor and get a mechanics mirror.
Old Apr 25, 2009 | 07:51 AM
bigfdaddy's Avatar
thanxs for all the help i have finnaly got them out. they were rusted and corroded into the handles. took form 11 am - 6 pm to get them out and replaced.
Old Apr 25, 2009 | 08:15 PM
oisinirish's Avatar
At least you got it. Good job! Got the ol rust bucket myself and kow what your dealing with. Almost wish I could be cross-eyed and see around corners sometimes..LOL
Old Apr 26, 2009 | 05:59 PM
bigfdaddy's Avatar
yeah it not to bad. could be worse. Broke the clip on the passenger side handle the the lock clips into on it so know looking for knew handles all the way around. and replace all at once.Since the truck is know in al from ny. im not worried about the salt and rust.
travlinsouth
Jun 18, 2011 11:54 AM
mbar
Nov 10, 2010 02:39 PM
Quicksilver
17
Feb 22, 2009 11:23 PM
rockettme
Aug 13, 2007 12:42 PM
Booztd
Jun 6, 2007 11:13 AM
