Door seal
Old Dec 12, 2007 | 07:25 PM
kiwi's Avatar
kiwi is an unknown quantity at this point
Default Door seal
Has anybody here had trouble with drivers (right hand drive)door seal? I have a 2002 Blazer and the seal where the door and the windscreen meet leaks. Even in light rain is leaks bad. I think the door may have dropped and is not sealing when closed.
Old Dec 12, 2007 | 07:32 PM
Default RE: Door seal
When you close your door, does the door lift up when it slides over the striker pin? It is quite possible that your door pins are worn, causing the door to sit lower, not properly compressing the weather stripping.
Old Dec 12, 2007 | 07:40 PM
kiwi's Avatar
I'll have check when it comes back to me. I can hear a lot of air coming through the door when driving.
Old Dec 17, 2007 | 03:07 AM
kiwi's Avatar
I've had a closer look and the door doesn't even close flat, so those pins will have to be replaced. Only seems to be the drivers door. The pin is all rusted and look worn.
MikeTastic
Jul 23, 2012 12:02 PM
96chevblazer
Apr 6, 2012 04:19 AM
BiggDaddyAK
Oct 12, 2011 11:00 AM
musclemasterflex
Sep 13, 2011 09:29 AM
litterbug
Mar 7, 2011 09:14 PM
