Door seal
Has anybody here had trouble with drivers (right hand drive)door seal? I have a 2002 Blazer and the seal where the door and the windscreen meet leaks. Even in light rain is leaks bad. I think the door may have dropped and is not sealing when closed.
When you close your door, does the door lift up when it slides over the striker pin? It is quite possible that your door pins are worn, causing the door to sit lower, not properly compressing the weather stripping.
musclemasterflex
Sep 13, 2011 09:29 AM
litterbug
Mar 7, 2011 09:14 PM
