Engine dies while driving 1989 k-5
Old Mar 1, 2009 | 01:47 PM
tonysrich's Avatar
tonysrich is an unknown quantity at this point
Default Engine dies while driving 1989 k-5
I have a 1989 full size 5.7l k-5. The engine dies (check engine light pops on then truck dies)while Im driving down the street (mostly between 2nd and 3rd gear). I have changed plugs,wires,cap+rotor,fule filter and still same outcome. Im going to change the fuel pump next and pray that dose the trick. I will keep you guys informed on my progress. Any Ideas are appreciated....
Thanks,
William
Old Mar 1, 2009 | 04:21 PM
Default RE: Engine dies while driving 1989 k-5
You say that the check engine light pops on. What code has been stored? To read the code, follow the directions on THIS SITE.
And before you go throwing a fuel pump at it, you should do a fuel pressure test to determine if the pump is even the problem. A TBI motor requires 8-10psi.
Old Mar 1, 2009 | 05:08 PM
tonysrich's Avatar
Thanks alot, I will follow instructions to the T.
Old Mar 1, 2009 | 05:52 PM
Hopefully the codes will point you in the right direction. Let us know what they are and we will move forward from there.
Old Mar 2, 2009 | 10:05 AM
tonysrich's Avatar
1st off thanks swartlkk for your help,Ok ,I have followed OBD instructions and have found FLASH, pause, FLASH, FLASH = code 12
Old Mar 2, 2009 | 10:25 AM
rriddle3's Avatar
IIRC, for OBD1 that is not a DTC, but just a 'system is ready to read' code.
Old Mar 2, 2009 | 12:16 PM
Yes, that is what it means. There should be further codes stored if the light is staying on while you drive...
Old Mar 2, 2009 | 12:26 PM
tonysrich's Avatar
The "check engine" light does not stay on while I'm driving (only right before it shuts down). The code just keeps flashing in the "ready to read" code 12 over and over with no changes in flash pattern. I have slightly above average auto knowledge and little time these days so I have committed my first sin and turned it in to a local shop. I will post the results here when I get results back.
Thanks for all the help guys !!
Tony
tammyjcks
Mar 29, 2020 10:05 PM
Flashgp
Jun 29, 2009 07:52 PM
sjrose
Mar 21, 2009 09:15 PM
sindy1232
Aug 22, 2008 09:38 AM
nickaf7172
Oct 6, 2005 03:36 AM
