Engine runs cold
Old May 23, 2011 | 11:11 AM
1992 blazer's Avatar
1992 blazer is on a distinguished road
Yes , I tested it and it seems to be working . I just took it out again and it only got to 150 . I checked the upper hose and it was hard so I believe it is holding pressure . The radiator was hot but touchable as was the upper hose . I'm at a loss .
Old May 24, 2011 | 10:09 AM
There is no such thing as having too large of a radiator. The thermostat regulates the flow of coolant through the engine. If the coolant is too cool, the thermostat will close down and wait for it to warm up.
Are there any holes in the thermostat? Is your heater core plumbed correctly? Anything that could allow for flow to bypass the valve in the thermostat?
Old May 26, 2011 | 08:23 AM
Latest news ... Finally got it warmed up . I had to completely block off the radiator with cardboard . Once i removed the cardboard it took about 5 mins to drop the temp back down to 150 . It was about 85 here yesterday so outside temp wasn't a factor .
Old May 26, 2011 | 11:52 AM
My statement still holds true. You have something that is bypassing the thermostat allowing coolant to flow through the system at all times rather than being regulated by the t-stat.
If you can, take some pictures of your engine including any lines to/from the engine that are thought to be coolant lines and post them here.
Old May 28, 2011 | 12:44 PM
Ok . Here is a couple of pics . If there's different views you need let me know .Engine runs cold-picture-1214.jpg
Old May 30, 2011 | 01:57 PM
Replaced t-stat again . No change . It's about 80 here today and temp will not go above 150 still . Hot air comes out of the heater but upper hose is not hot . This sucks .
Old May 30, 2011 | 03:27 PM
oisinirish's Avatar
Is there a fan clutch? It could be stuck/dirty? Would that cause it? Google that one os may not apply. Centrifugal release between fan and pump?
Old May 30, 2011 | 04:03 PM
84BlazerS10's Avatar
When mine had a bad fan clutch it ran hot so I would think that wouldn't be a problem.
Old May 30, 2011 | 04:38 PM
I can spin the fan by hand . I had a buddy hold it while I started the enginge so I think the clutch is ok .
Old Jun 7, 2011 | 02:20 PM
I took it to a shop today and they claim that it had 10 codes in the computer . I had checked it earlier using the jumper method and there were no codes . They are claiming i need a new ECU or chip . I will get the codes and post them later .
