Faulty gas gauge reading
Old Sep 27, 2010 | 03:37 PM
83GMC-JIMMY's Avatar
83GMC-JIMMY is on a distinguished road
Default Faulty gas gauge reading
I'll make this short. The gas gauge on my 1983 GMC JIMMY reads 1/4 tank even after I've filled the tank. The gauge will go down as fuel is consumed, however, I don't know how accurate the reading is The tank was dropped in August of this year and a new sending unit was installed. Outside of the possibility of new sending unit being bad, what else could be causing this? Any help is much appreciated.
Old Oct 1, 2010 | 07:50 PM
KaneK5's Avatar
KaneK5 is on a distinguished road
i had just about the same issue, must times it would read 1/4 tank some times after filling it would only read 1/4 then jump to full but 90% of the time it stayed in same spot. mine ended up being a bad ground wire mounted to the sending unit and corrosion on the power wire. Hope it helps if thats not it faulty gauge and or wiring issues els where.
Old Oct 6, 2010 | 09:06 AM
Thanks for the tips Kanek5. Getting to those wires means dropping the tank again, but I don't see any other way around it.
BlazeOn
68
Feb 7, 2019 10:24 AM
bostonblazer22
Mar 21, 2012 06:53 AM
2wings4me@ntelos.net
Dec 29, 2010 11:25 AM
88s10Blazer
Jan 27, 2010 04:44 PM
devestator_x
Dec 26, 2007 10:08 AM
