Fuse for ECMB
Old Jul 18, 2009 | 11:47 PM
NorCalK5's Avatar
NorCalK5 is an unknown quantity at this point
Default Fuse for ECMB
I have a 90 Chevy with the 5.7 tbi, yesterday i drove over a speed bumb at a speed little over reccommend speed, and the truck shut off right away. try to start it and the tbi wasnt squirting. so i checked the fuses and the ECMB fuse was blown, i changed it and it started back up. well i drove about 1/2 mile when i hit a pot hole and the fuse popped again. This time when i changed the fuse, as soon as i key the ignition it popped. Any suggestion? Im thinking maybe an exposed wire for the fuel pump is grounding out.
Old Jul 21, 2009 | 11:04 PM
mswoape's Avatar
mswoape is on a distinguished road
yeah exactly!! i just bought a k5 blazer on saturday doing the same thing. my ecm-1 fuse was popped and there was a pile of them in the floor. i found where the wire was exposed and put heat shrink over it. no more problems. let us know what you find.
Old Jul 21, 2009 | 11:13 PM
mswoape's Avatar
also if you have trouble finding where the ground is... wire in a light where the fuse goes, using two spade connectors... turn the key on and it should light up... it will go out when you find and disconnect the ground. good luck
Old Jul 21, 2009 | 11:31 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
please do not double post it is againt Forum rules, next time just use the edit feature in the bottom right hand corner of your post.
Old Jul 22, 2009 | 08:20 PM
NorCalK5's Avatar
I cant seem to find where it is grounding out at. I looked all along the frame rail, i double checked. Is it possible the Fuel pump is bad?? I have already changed the Fuel Pump Relay. Cuz the Fuse seems to be popping when the rear of truck bounces to heavily.
NCSurvival
Sep 10, 2015 05:54 AM
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
snakey
May 2, 2012 03:10 PM
dumptruck1990
31
Apr 4, 2011 02:30 PM
