hard gas pedal
Old Mar 16, 2009 | 05:41 PM
92K5BLAZER's Avatar
92K5BLAZER is on a distinguished road
Post hard gas pedal
ya i just bought a beautiful 1992 k5 blazer. It runs great and all, but the gas pedal is hard. Just your intial push to get it going. It seems like its stuck ono something when it comes back. But once you get it going its fine.
Any suggestions?
Old Mar 16, 2009 | 05:54 PM
Biohazed's Avatar
sounds like the cable that goes from the gas pedel to your throttle baby have some rust in it. you can try to work some lube like silicone spray into the sheathing but you may be better off getting a new cable
Old Mar 16, 2009 | 10:19 PM
I would bet that it is a carbon'd up throttle body. You can clean it without removing it, but it would be best to remove it and go over it thoroughly.
Old Mar 21, 2009 | 03:13 PM
EnyChevyUK's Avatar
EnyChevyUK is an unknown quantity at this point
I have the same problem on my 88 K5. I tried lubricating the cable from the pedal to the top of the engine without any luck.
How do you clean the TB without removal ?
Old Mar 21, 2009 | 04:07 PM
Some carb cleaner and a brush. You really should remove it though.
Old Mar 21, 2009 | 04:12 PM
PVT Pablo's Avatar
PVT Pablo is an unknown quantity at this point
My blazer does the same thing too. The initial push is an effort, but after that, no issues at all.
Old Mar 25, 2009 | 09:22 AM
Dennis The Menace's Avatar
Dennis The Menace is on a distinguished road
Had the same problem on my '90 Blazer. Spray Carb cleaner used to clean out the cable, two different types of lube, and it worked for a short time. Problem came back and repeated the process. I was ready to replace the TBI body because I found a worn shaft that "might" have been the problem, but decided to replace the cable first. Found it at the dealer, about $35.00 and it fixed everything. Never did replace the TBI body and haven't had a problem yet. It's even an easy replacement.
Try this, when you disconnect the cable from the throttle body, operate the TBI lever and see if it is hard to move by hand. If you don't feel that initial hard effort to move it, it's probably the cable. And, it's a lot cheaper and easier to replace the cable, although cleaning the TBI throttle blades is not a hard job.
Good luck and let us know what you find.
skier150
16
Nov 17, 2013 10:06 AM
zstudna
May 29, 2012 06:06 PM
NYCJUDGE
Aug 28, 2011 04:35 PM
comart45
Feb 25, 2010 10:05 PM
bang4dabuck
Jan 13, 2010 02:27 PM
