harsh shift from 1st to 2nd no loss of power no engine light just HARSH
Old Feb 9, 2012 | 11:03 AM
jpasillas94blaze's Avatar
jpasillas94blaze is on a distinguished road
Default harsh shift from 1st to 2nd no loss of power no engine light just HARSH
i bought this 94 blazer full size with 350 4x4. This is my second 4x4 truck and i am fairly new to them but am a practicing mechanic that just needs to be pointed in the right direction. It has a 4 inch lift i assume and everything works its got about 154k dude says trans got rebuilt and has a shift kit. its got 33s on it also. so the only problem is its very harsh into second gear ONLY all other gears shift perfectly fine there is no loss of power or gas mileage. some local tire mechanic told me the noise im hearing is my t-case mounts and i think he is full of **** but who knows. ive seen previous threads on this but i felt need to customize my own problem into one thread. please if any one can help me id greatly appriciate it ! thanks in advance guys!
Old Feb 9, 2012 | 11:15 AM
70-K5's Avatar
70-K5 is on a distinguished road
So is the problem the hard 1-2 shift or is there a noise associated with the shift?
A shift kit can cause hard fast shifts from 1-2, this is not a bad thing, just need to get used to it.
Old Feb 9, 2012 | 01:28 PM
I agree that it might be a shift kit that is affecting things, but it could also be an improperly adjusted TV cable. Run a google search for "TV Cable Adjustment" and you should find the procedure for adjusting it properly. Run through that and let us know how it feels.
Old Feb 9, 2012 | 05:16 PM
70-K5's Avatar
Or you could read this:
Bowtie Overdrives | TV Made EZ
Best article on the net for describing the f(x) of the TV cable.
Old Feb 10, 2012 | 10:22 AM
It has a sort of clunk to it when it shifts into second every time cold or hot doesn't affect it. From take off I also hear a bang if I torque it almost like metal hitting metal by the t case. Maybe a tranny mount? The shift is really hard and always the same
Old Feb 10, 2012 | 07:45 PM
ericthughes's Avatar
ericthughes is on a distinguished road
do those newer trucks have a detent valve?
Old Feb 19, 2012 | 10:47 PM
Checked tv cable it Is fine I'm trying to get a tranny mount in tomorrow hopefully that helps.
bryanmine
May 19, 2011 11:27 AM
Blessed23
Mar 30, 2010 08:38 PM
lstfld
Mar 14, 2008 07:06 PM
brock
Aug 15, 2007 11:45 PM
ginobass
Aug 6, 2007 01:08 PM
