Help!!!! backfireing problem
Old Feb 16, 2010 | 05:16 PM
88chevyblazer's Avatar
88chevyblazer is on a distinguished road
Exclamation Help!!!! backfireing problem
I have a 88 chey blazer k5,, i'm having a problem with it backfireing when i step on the gas and it is also running alittle rough.. i change the spark plug, wires, distributor cap, coil, adjusted the timeing, change the fuel fliter and rotor...... i can't think of anything else to do .... can anyone help.. thank you,
raylene
Old Feb 16, 2010 | 06:13 PM
What did you set the timing at? Or did you just rotate the distributor on a whim?
Old Feb 16, 2010 | 08:24 PM
bigfdaddy's Avatar
bigfdaddy is on a distinguished road
check the timing on the crank or could be needing a valve job
Old Feb 17, 2010 | 08:28 PM
i did the timing light on it!!!
Old Feb 17, 2010 | 08:37 PM
I am assuming that you have the TBI 350 here...
To set the base timing on this motor, you must first disconnect the 'set timing' connector (tan/black wire close to the distributor). The engine should be up to normal operating temperature and the A/C set to 'off'. The transmission should be in neutral and the wheels chocked.
Set it to 0* to the #1 cylinder.
The crucial step here is to disconnect the 'set timing' connector.
Old Feb 18, 2010 | 01:37 PM
yes i set it to 0....
and i try move the distributor
Last edited by swartlkk; Feb 18, 2010 at 01:39 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Old Mar 10, 2010 | 09:10 PM
Sadchevy's Avatar
Sadchevy is on a distinguished road
check your plug wires and make sure they are on the proper plugs. small blocks will idle quite nicely with the two rear passenger side plug wires swapped but backfire under load .
Old Mar 12, 2010 | 01:05 PM
k5purplehornies's Avatar
k5purplehornies is an unknown quantity at this point
I had a similar problem... ended up being a flat cam lobe, so maybe look that direction.
MyBlazerSucks
Jan 5, 2012 12:02 AM
English5
Jul 16, 2010 11:11 AM
soky25
Mar 15, 2010 05:33 PM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
