idleing down, stops running.
Old Apr 11, 2007 | 01:35 AM
throttlesteer's Avatar
throttlesteer is an unknown quantity at this point
Default RE: idleing down, stops running.
ORIGINAL: thevair65
the battery was replaced about a month ago. as far as the alternater goes, it puts out a steady 14 amps. it rattles and makes some odd noices but as far as i can tell its working.
14amps is nowhere near where it needs to be. I think you may be thinking of 14volts, which would be accurate (actual should be 14.4v). Ampres should be upwards of 85+ depending on options and what factory spec is. Get it bench tested to eliminate it from the possibilities. If it's making noises already thats a sign that it is or could be on the way out soon.
Old Apr 11, 2007 | 02:25 AM
thevair65's Avatar
thevair65 is an unknown quantity at this point
i was told it was amps but i am not realy sure.\
either way the guage sits at 14. and from what ive been told thats within opperating tallerances but again just one more thing im not sure of.ill bench test it. even if its not broken it makes my truck sound like crap with its rattleing so ill replace it either way.
Don Bennett
Aug 31, 2012 04:30 PM
bigbird82
Nov 22, 2011 04:32 PM
JMAC
17
Apr 7, 2009 11:32 AM
JMAC
Mar 22, 2008 12:04 PM
blazergirl15
Jun 6, 2005 02:02 AM
